SteveOh wrote:yasser wrote:there is an ignition live under the drivers seat. page 142 bemm explains
Thanks for replying Yasser..
Not in the version I just downloaded... which section is it in?
Sorry, my mistake, its page 149 and this is the section.
4.18.4 Vehicle Interface Connector there is a little plug that will give you 4 connections and one of them is an ignition feed, number 4 pin.
I just used it for a relay and took my power from the 60a feed on the drivers seat. there is a plug for it but its about £50 from ford. I just got a very tiny female spade connector from maplins, closed it up abit, connected wire to spade connector and then heat shrink it to insulate the whole thing and then just pushed that on to pin number 4, i have put a picture on here somewhere on here of the part number if you want to get the proper plug at a later date.
This link might get you there
https://fordtransit.org/forum/viewtopic ... r#p1258483
