Hi all
My 2015 fwd Custom has previously had the following mods without issue:
Hard pipe induction tube from hose off turbo across to drivers side headlight and cone filter
Remapped with DPF removed
2.5" throttle side boost pipe along with a massive front mount intercooler
Van had a noticeable improvement in power after intercooler and pipework upgrade as they were the most recent mods.
At the weekend I fitted turbo side hard pipe that is 2.5" from turbo to cooler without the stupid silencer thingy and reduced the length of induction pipe with cone filter now at the passengers side
The van revs free and drives great for 5 minutes before going into limp mode and showing code P00BD "Mass or Volume Air Flow 'A' Circuit Range/Performance - Air Flow Too High
Obviously I know what is causing the issue but my question is does anyone know a way to either trick the system or can a mapper adjust the set limits the ECU looks for?
The performance gain is enough to justify wanting to find a fix rather than just stick the tiny stock hose back in
Thanks for looking
