dashboard light dimmer
Postby madmaori » Thu Jun 22, 2017 6:35 am
Just put a ford focus light switch (easier to find on ebay)in so I can dim the dash board lights,goes saweet.
madmaori
Re: dashboard light dimmer
Postby Gazz173 » Thu Jun 22, 2017 12:56 pm
Thought that feature was already standard in the vans, 2 buttons to the left of the headlight controls on mine.
Gazz173
Postby madmaori » Thu Jun 22, 2017 7:39 pm
only an option here in NZ I guess.
madmaori
Postby loot » Fri Jun 23, 2017 9:03 pm
Pictures? :-)
07 350 170ps
Ids map here
loot
Postby madmaori » Mon Jun 26, 2017 8:49 am
done
madmaori
auto lights go as well.
madmaori
Postby loot » Mon Jun 26, 2017 9:44 am
Sweet :-)
My uk custom limited has the same switch, some show less auto and i presume dimmer.
Easy mod then 8)
07 350 170ps
Ids map here
loot
Postby Veteran » Wed Jun 28, 2017 6:39 am
So my 2013 Custom has no dimmer either. If I get the switch with dimmer from the focus, is it just plug and play ?
Or is there wiring to be done to get dimmer to work ?
Veteran
Postby madmaori » Tue Jul 11, 2017 5:46 am
yes,just put it in.
madmaori
Postby madmaori » Tue Jul 11, 2017 5:47 am
no wiring needed
madmaori
Postby nforcer » Fri Nov 20, 2020 10:31 am
Hey guys,
i tried it with my Transit Custom '14 with a headlight switch from a transit connect. But the dim buttons show no effect.
Also the front and rear fog light wont work any more.
Any suggestions? I noticed my cable going into the switch only has 4 wires, but the switch has 6 pins.
Cheers Matthias
nforcer
Postby loot » Sat Nov 21, 2020 12:04 pm
Not much info on newer ford's unfortunately. It seems like there's a secret way to upgrade things. There's a lot more module dependencies and just swapping things doesn't seem to work. Someone needs to spend some time trialing from the base equipment to the limited equipment to see how it all connects. That said though it should be just a simple resistor :?
07 350 170ps
Ids map here
loot
Postby Kardaani » Sun Nov 22, 2020 7:45 pm
Did i figured out this right? If you have 2013 made custom you can simply take lightswitch from focus and you get dimmed dashboard and autolights just like that? And if you have 2014 made custom like i do, it wont work?
Kardaani
Postby nforcer » Tue Nov 24, 2020 12:09 pm
News: It worked. You just have to start the engine :roll:
nforcer
Postby Kardaani » Thu Nov 26, 2020 7:33 pm
Do you have also working autolights now? Or did i misunderstood madmaoris post "auto lights go as well" ? I dont actually care about dimmable dashlights, but auto headlights with taillights would be nice.
Kardaani
Return to Transit Custom
Users browsing this forum: steve58
