bigjohnthomas wrote:A couple of relays that break the connection to the odb plug and a fancy switch to turn it on So folk think they have bought somink right fantastic
One hundred quid lolzzzzz
Its making my gravy go curly
bigjohnthomas wrote:Well then.. Why would you want it to "arm" itself when you turn the key off ? How many times a day do you use the odb port? You might as well just cut a wire going to it and put a switch in somewhere if your so inclined
Profiteering on people's fears
Scare the sheeple
Steer the sheeple
Gasman82 wrote: are these drivers door locks that people are fitting worth the money??
