PHILLIPS H7 LED HEADLIGHT KIT
Postby Ryanjones0143 » Wed Jul 05, 2017 4:10 pm
http://www.horizonleds.co.uk/h7-5th-gen ... 0%20Lumens
Has anyone tried these?
Will the bulbs fit through into the projector lens and do they throw up any CANBUS issues?
Cheers
Ryanjones0143
Re: PHILLIPS H7 LED HEADLIGHT KIT
Postby Nederbelg » Wed Jul 05, 2017 6:53 pm
Firstly: this Set isn't a " Philips" set!! It only uses supposedly "Philips" LEDs. In other parts off the world, Philips does sell automotive LEDs whith Lumileds in them. This one isn't a genuine Philips.
I've tried the same ones (or very similar), bought from Aliexpress for around £35 :shock: They did cause Canbus problems, which can easily be solved by a parallel Resistor ( 10 Ohm, 20 Watts). But then came the real surprise: radio reception was very poor whith the lights on.!
The beam pattern was very poor as the focal point off the LEDs were several Millimeters off. After adjusting this, it was OK.
I would ask for a reassurance that radio reception isn't disturbed by the LEDs
Gr Nederbelg
Nederbelg
Postby S60r » Wed Jul 05, 2017 11:45 pm
Best ask Mike on here... I think he was trailing a set of these? He wasn't impressed at all.
I don't think you will find the lighting is on the CAN system. We get no warnings when a bulb is out. well on the Euro 5 anyway.
S60r
Postby BNObournemouth » Thu Jul 06, 2017 1:08 am
DO NOT BUY THESE BULBS... SH1T is an understatement!
Everybody... DO NOT BUY!!!
BNObournemouth
Postby Mike » Thu Jul 06, 2017 8:44 am
I've been trying them as the main beam on a Connect, they're very bright but they don't have any range and the beam pattern is uneven. Seikokid has tried them in his Custom as dip beam, his results haven't been encouraging. Hopefully Philips will make some available soon, then we'll have a realistic opt.
(The picture on the site that you linked to is of the H4 bulb)
Mike
Wind up merchant!
Postby Ryanjones0143 » Thu Jul 06, 2017 6:29 pm
Cheers guys! I won't bother then!
Guess I'll stick to just upgrading the bulbs as HID's don't seem to work in later Customs either
Ryanjones0143
Return to Transit Custom
Users browsing this forum: Bear3009, Majestic-12 [Bot]
