S60r wrote:You are obviously out of the Ford 3 year warranty period.... I would remove the dpf and remap it. You'll never have any more trouble that way. There are many companies out there doing it, try looking at Celtic tuning. The figures they quote are famously inflated but they can remove the dpf and write it out of your software. They can also hollow it out and leave it in situ so MOT won't be an issue. I would ring and talk to a couple of companies and they can alleviate any fears you may have about passing future MOT and emission tests.
People will tell you it can't be done, but there are hundreds out there with it removed and you'll have no further problems. A removal and remap will be around 600 quid whereas a replacement will be well over 3 times that and you will block it again. My van is my own and when my DPF fails it will come off along with the EGR and it will be better for it.
S60r wrote:Yes Paul.... nothing I didn't know.
Mine will still be removed. If there was a petrol option in the Transit I would have definitely bought it.
A roadside check will be visual, the emissions is the biggest talking point here..... mine without DPF and EGR still passed both the smoke and emissions..., yes I made sure to present it with a red hot exhaust system but there was no problem, which asks the question "what do they do anyway?"...
Yes no doubt removing them is not legal as far as DVLA or the mot go, but to replace a broken one is in the thousands of pounds and the vehicle runs better without them. Halfords testers certainly didn't recognise mine missing and ther are plenty of friendly testers out there.
loot wrote:I think it'll be a case of wait and see, for most.
I'll be interested to see how many fights break out between mechanics trying to dismantle the vehicle and customers who feel violated at the sight of this
As always this forewarning they give us does usually make it look worse than it is.
In fact i still see things happening that is illegal and that was largely discussed in public and caused anger at the time but is nothing to mention these days.
My advice to anyone wishing to bypass or circumvent the emissions related parts of the van should keep the parts they remove and keep in touch with the person doing the reprogramming so that they can swap and change if necessary
bambi mk 1 wrote:loot wrote:I think it'll be a case of wait and see, for most.
I wonder what the case would be for a second or third offence on the same vehicle I believe they are to use some kind of blotting paper over the exhaust over here when it comes into force,so no need to check the dpf insides
