To check weather DPF, EGR valves are are functioning or not. By using a suitable device via DLC than can read & record vehicles current live data.
I myself can check DPF's EGR's functionality in less than 5 mins It's that simple.
Combine that with a visual check. For example egr blanking plates etc. It's a no brainer.
Although Euro 6 & late Euro 5 engines do have the facilty for emissions (Including NOx) to be checked via DLC
- One of the reasons why MOT rules regarding diesel emission are do to be changed later this year.
Get caught with missing or blanked of EGR's or DPF deletes. Then you'll be given 10 days to have fault rectified. DVSA will give you a ticket.
Of which then you'll have to provide to Dealership/independent garage for them to repair the fault & then inspect to verify repair has been carried out.
SO just for a simple EGR blanking plate that you remove yourself at no cost. Only to have to shell out £££ to have vehicle inspected to verify defect has been repaired/corrected
You must then provide DVSA paperwork of completed repair & inspection. Failure to do so will result in a fine upto £5K & your vehicle prohibited from being used on the road.
Due to being NOT roadworthy under Construction of Use regs. - We all no how DVSA prohibited vehicles from being used on the road. They seize then crush them
Point is. I politely informed this forum nearly 2 years ago that 2017 would be the year when rules would be changed/added regarding DPF /EGR deletes. People said then "it would never happen", Can't be enforced" etc.
Fact is. It's going ahead as planned. Even today people are still saying it will never happen.
This is just the start. Below is what's coming
NEXT
Government has orderd 5 cities to have CCAZ (Charging clean Air Zones) implement by 2019.
They are as follows -
Birmingham, Leeds, Nottingham, Derby &
Southampton.
Other cities will have CCAZ final plans by 2018.
Zone Class & emission standards are below.
Road Tax for Diesels to be increased in Autumn Budget.
2017 Consultation for Alternatively fuelled light commercials (Vans) - Elec or Hydrogen powered.
Look like Diesel engine vans are rapidly reaching the end of the line.
Don't shoot the messenger. I'm here to help & advise
