user774 wrote:I saw a custom yesterday that had no driver's lock at all. That's the best security update I can think of. Presumably it's a continental custom's passenger's door simply imported and installed.
Ok, if the battery goes flat he has to smash a window, but it's his window to smash. 10/10.
andythenorth wrote:Frag wrote:It's a later calibration of the body control module,which removes the facility to unlock rear and side door by double unlocking using the key in door lock barrel itself...
Any idea if it also stops the alarm being disabled if someone cracks the lock barrel out of the door panel? Cos that's an outstanding security feature
bigjohnthomas wrote:If the doors opened the alarm goes off unless a coded key is put into the ignition init boss
andythenorth wrote:bigjohnthomas wrote:If the doors opened the alarm goes off unless a coded key is put into the ignition init boss
In Ford advertising fantasy land yes
What really happens: take some big grips, apply them to your door lock, twist until the lock cracks out of the mount. Hear any alarm? Nah. All you hear is the nice 'clunk' of the central locking opening all doors. That nice absence of 'beep beep beep' you hear? That's your alarm, not going off. Your immobiliser is off too, for bonus points. Because there's a push rod behind the lock connected to a switch that turns all this off. Enjoy yourself
No space lasers needed. I wouldn't share the info, but the Daily Star and a bunch of other big sites already did so eh.
How do I know all this? "Here's one I made earlier"
hitech-donk wrote:Anyway as the door is screwed anyway and being quoted around £400 for a bare door
bigjohnthomas wrote:You have unlocked it but as soon as you open the door the powerful ultrasonic sensors in the interior light will spot a movement and bleep bleep the alarm will go off.
ake wrote:andythenorth wrote:bigjohnthomas wrote:If the doors opened the alarm goes off unless a coded key is put into the ignition init boss
Bollocks.
IF you have an alarm, then if the door is unlocked with the key, you then have to put a coded key in the ignition and turn it to position two
The main issue, other than the sh*t locks, is the fact that very very few vans have stock alarms, cos
Everyone is to f*** miserable to tick the alarm option box on the order form.
ake wrote:IF you have an alarm, then if the door is unlocked with the key, you then have to put a coded key in the ignition and turn it to position two
S60r wrote:Mine is dciv and when the alarm sounds it is the horn not a beep! I'm not sure yours is functioning properly either way as the alarm sounds even if you have unlocked the van by the key. I would get yours looked at as something isn't right.
Also, if your battery is flat and some folk have removed the lock from the door........ isn't it cheaper to unlock the bonnet and power the van from the jump points than smash a window????
Can't understand why you'd need to smash a window!
