Hey its been a while since I posted. Usually I'm in the mk6 area but I'm trying to find out info regarding my work van to winge to my boss about.
My work van is a 15plate custom. It has an invervter in the back which I would like to use for work. However
The van has never given me a volt reading over 12v usually its 11.8v in a morning even after a good run the previous day.
In my head this is too low.
I have a camper comversion with aux battery for my inverter. I dont think they've had these vans set up like that..
To use my inverter I have to start the van. Leave the drivers seat. Climb in the back to turn the inverter on. As the inverter reads a low voltage and wont run if the vans not running.
Witht the whole engine off to use then the phone now. Leaving the van with the engine running is in the same legal realm.
Its been in and checked but just this morning I did the above to charge a drill battery on my way to a job. One turn over of the engine and a 10min charge on a 4ah drill battery has killed it as I had to turn the van off for 10mins to send a couple of emails.
Any thoughts?
Sent from my SM-N910F using Tapatalk
