eberspacher fuel take off at the tank sender
Postby psv-hgv-flt » Fri Sep 08, 2017 8:43 am
is there a eberspacher fuel take off at the tank sender unit on a 2.2 16 reg 155bhp custom.
thanks crh 07951097828
psv-hgv-flt
Re: eberspacher fuel take off at the tank sender
Postby se7en » Fri Sep 08, 2017 12:52 pm
There is on my 14 reg 155
se7en
Postby ake » Fri Sep 08, 2017 7:45 pm
Yes. Full details in the BEMM you can download at www.etis.ford.com
Postby loot » Sun Apr 15, 2018 5:55 pm
I've seen that you can either go into a supplied canister which i have, or into the fuel sender, you buy an in tank pipe kit and cut the top off the inlet port.
Also seen that you can just T into the fuel pipe.
What's best?
Ids map here
loot
Postby dumper » Sun Apr 15, 2018 9:51 pm
I know not a custom but my mk8 I used the tank sender kit
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby loot » Sun Apr 15, 2018 10:23 pm
So you dropped the tank then cut the top off, inserted the pickup pipe and put the connector on for the heater?
Did you use 1 for the mk8 or the 1 in the link?
Ids map here
loot
Postby dumper » Mon Apr 16, 2018 8:35 am
Yes loot that’s what I did I whent to butler technic with the kit I got for my mk6 I had the drinking straw and the adapter left over as I did not use-them they said even though I bought the kit 9 years ago it was the same kit even the diagrams and photo was the same they sold me the rubber and plastic pipe to make up the full kit.
So I dropped the tank cut tip off and fitted the straw and adapter with this setup the heater cuts off at about 1/4 of a tank on mk6 it was 1/8 of a tank
As I didn’t want to fit it to mk8 on the drive at home I whent to the garage that do my mots and did it on the ramp with one of his mechanics so was a pay job so just fitted it as instructions if I’d been able to do it at work like the mk6 I’d have just cut off the tip and fitted the larger bore pipe straight onto the tip and tried the heater to see if it would work and not used the straw and adapter as nobody at Ford could tell me if the stand pipe was the same as mk6 and whent to bottom of the tank the only problem was the kit uses the small bore pipe and the pump uses the larger bore pipe on the inlet so small bore pipe takes a bit of forceing on
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Suurpepu » Mon Sep 06, 2021 11:03 pm
Hi guys
I am going to fit a cheaper Chinese heater in mine Mk 7 and decided to go into the tank. I followed this thread and am thinking of buying the kit from Butler.. however it says it is specifically for Eberspacher heaters. I can’t see why but any thoughts on whether it makes a difference what heater is picking up the fuel? Its 2kw
Also, there are so many stand pipe kits on EBay for about a £10, But I’m not sure what length Pipe I need to get anyone know if these will work? On a Budget! Thank you
Kerry
Suurpepu
Postby dumper » Tue Sep 07, 2021 7:15 am
My tank feed is the butler one when I fitted it I was running a D3lc Eberspacher I have now swapped it for a Chinese one and the feed pipe is the same bore so it’s the same straight fit you should have no problems .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby loot » Tue Sep 07, 2021 2:55 pm
Mine too it's all the same but the name :D
Ids map here
loot
Postby dumper » Tue Sep 07, 2021 3:41 pm
Yes Loot the only thing I used from the new heater pipe work was the hot air outlet pipe from the heater to the outlet vent the Chinese one supplied was to tight to fit on the heater and needed to be slightly longer as the casing was shorter then the Eberspacer.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Suurpepu » Wed Sep 08, 2021 4:58 pm
Thanks guys
Ordered a Butler one
Suurpepu
Return to Transit Custom
