Wandering gently
Re: Swerving
Postby ned » Sun Sep 10, 2017 10:02 pm
loot wrote::lol:
My snapon tool chest is located there:-)
So to recap, i need some extra weight in the back and something to counteract my arms and the effects the steering wheel.? Hmmm it's on the tip of my tongue the perfect solution i can feel it........
When I worked for alfasound I used to drive from Manchester to Bath everyday In a jumbo LT35/crafter fully loaded going was a nice drive but coming back empty the van was a bloody nightmare, any slight wind and it was all over the place or was that cos I was tired by 10am :wink: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: Swerving
Postby DrDeAtH » Thu Sep 14, 2017 10:18 pm
Loot, check that your track rods are straight, although the alignment is ok, a bent one might give the symptoms you are experiencing.
DrDeAtH
Re: Swerving
Postby loot » Thu Sep 14, 2017 11:56 pm
I did straighten the left 1 but it may be a whisper out, (not overly critical to me given that they are service items but I plan to replace it possibly both as an overkill) I'll see if it helps :-)
07 350 170ps
Ids map here
loot
Re: Swerving
Postby Colr6 » Sat Sep 16, 2017 9:36 pm
A seized/ tight suspension or steering ball joint would give you the symptoms
Colr6
Re: Wandering gently
Postby Shaun306 » Sat Sep 23, 2017 9:08 am
I get this.....put it down to after market wheels on mine, it is rather annoying
Shaun306
Postby loot » Sat Sep 23, 2017 12:28 pm
I'm glad it isn't me :-)
I can confirm that everything is loose/smooth i remember thinking surprisingly freed off for 4800 miles on the clock :? But then being a hilti van i expected similar use to a post van.
Only bothers me on long runs and nobody says that they feel any different as passengers so it is literally hope i lean on the wheel minor corrections to follow the road.
07 350 170ps
Ids map here
loot
Return to Transit Custom
Users browsing this forum: Google [Bot], MartK
