Stalling on gear change
Postby si4star » Wed Sep 13, 2017 3:55 pm
Hello,
I've got a 2013 2.2ltr diesel transit custom swb. 63 reg with 56k miles on.
Recently it began to stall on gear down changing.
I'd put the clutch to the floor, take it out of third, move it to second and by the time i lift the clutch the revs have dropped off and the vans stalled.
It's happened 4-3 and 3-2. Thankfully no accidents yet - despite it happening moving onto a slip road at 40+mph.
I've had the van into Ford three times now, 10 days in total.
They've relearned, and "updated the software" and it's still an issue.
Other symptoms (which may or may not be related) are;
- sometimes it won't start immediately and the starter fires for up to ten seconds before the engine starts (starts sooner if it touch the accelerator)
- the revs wobble all the time, be in in gear with the clutch down or in neutral
- the revs fluctuate quite a lot as I drop and lift clutch
All symptoms including the gear change stall are infrequent. The gear change issue can happen 5 times in 10 minutes, then not for another few hours.
It's really taken the shine off what has been a great van so far and it's really starting to get me down that even FORD can't fix their own van.
Please can anyone shed some light on this? I'm hoping to find someone that's had an identical issue resolved. Fingers crossed.
Thanks.
Simon
si4star
Re: Stalling on gear change
Postby Flatfour1 » Wed Sep 13, 2017 9:51 pm
Sounds like the clutch switch could be playing up.
Flatfour1
Postby si4star » Fri Sep 22, 2017 9:31 am
Bang on. Clutch switch replaced. Took you an hour, took ford 20 days. Thanks.
si4star
Postby Altransit » Fri Sep 22, 2017 11:40 am
si4star wrote:Bang on. Clutch switch replaced. Took you an hour, took ford 20 days. Thanks.
:lol: Always check with the FTF first, you'll be amazed at the knowledge database on here :wink:
Thanks for posting back to confirm :D 8)
Postby Flatfour1 » Fri Sep 22, 2017 6:45 pm
:) Glad you got it sorted.
Flatfour1
Return to Transit Custom
