Turbo reliability on 2.2
Postby Damien89 » Fri Sep 22, 2017 9:23 pm
Hi, i have a question, those with the 2.2 euro5 engine, have you had turbo actuator failures?
Because here in Malta ALL mk8 minibuses with the 2.2 engine rwd have had there turbos replaced under warranty due to the actuator failing. I'm asking here because to my knowledge the 2.2 in the custom is the same as the 2.2 found in the mk8 vans/minibuses.
Damien89
Re: Turbo reliability on 2.2
Postby dan_robinson » Fri Sep 22, 2017 11:27 pm
Apart form a vacuum hose failure, mines been perfect.
dan_robinson
Postby nickc1234 » Fri Nov 24, 2017 12:05 am
Had my turbo replaced at 76k. I believe the actuator is attached to the turbo so you have to replace the whole unit?
nickc1234
Postby karl » Fri Nov 24, 2017 5:49 pm
I have just replaced an engine because the turbo failed
2.2 rwd euro 5 and this is its second engine
and I think the dpf is back pressuring and shearing the shaft
the cat and dpf are restricting the power of the engine when it is trying to exhaust
karl
Tranny Lover!!!
Return to Transit Custom
