Does anyone please have an engine diagram
Postby Alternative2 » Sun Oct 22, 2017 7:43 pm
Hiya bit of a big ask but does anyone have an engine diagram of the 2.2 transit custom please?
Just trying to figure out what a noise is and what the part that could be making it haha.
Cheers all
Alternative2
Re: Does anyone please have an engine diagram
Postby Altransit » Sun Oct 22, 2017 7:59 pm
What sort of noise is it :?:
Postby Alternative2 » Sun Oct 22, 2017 9:59 pm
Well it's usually on tick over it sounds like something is clattering or some sort of banging in time with the engine if that makes sense from looking under the bonnet it's at the left hand side at the top behind the filler for washer bottle. I've had the pulleys done (bottom of engine) and this noise seems like it's coming from the top above the pulleys and tensioner etc. But at the back of the engine. When I rev it up it goes a lot quieter possibly even stops but can't be 100%.
Alternative2
Postby Nederbelg » Sun Oct 22, 2017 10:03 pm
Vacuüm pump, maybe?
Gr Nederbelg
Nederbelg
Postby moley551 » Sun Oct 22, 2017 11:06 pm
Have you tried turning the aircon on and off while you listen my aircon clutch rattles like a bag of spanners at idle, I have had some idelers changed under warranty but the aircon is still noisy.
"Don't find fault, find a remedy"
H. Ford
moley551
Postby Altransit » Mon Oct 23, 2017 10:44 am
Clattering/Banging on tickover sounds horribly like a degrading Dual Mass Flywheel :(
Postby Alternative2 » Mon Oct 23, 2017 11:50 am
Hiya,
Re the vacuum pump. That's a possible one but to be honest I wouldn't even know where it was haha.
As for the flywheel, this was replaced a few months ago and judging by where the noise is coming from its not close to the flywheel etc so hoping it's not that again.
I've listened to it from all angles and it's definitely top left land side of engine while stood at the front.
Strangely with the air con turned on its not as bad :-/ firstly makes a rattle when the pump kicks in but then eases off.
Bloody ford's haha
Alternative2
Postby loot » Tue Oct 24, 2017 10:23 pm
Can you post up a video of it? Could be many things.
Mine was on 4800 miles and was tapping, turned out a dud injector :shock:
Ids map here
loot
Postby stchris356 » Wed Oct 25, 2017 10:31 pm
I've had a new timing belt idler pulley due to it rattling mainly at idle.
stchris356
Return to Transit Custom
