Hi, I have a 2014 custom 100 ps and last week I got the engine malfunction info and then the EML. As this had never happed before I called breakdown and it was the error P00BD: Mass or Volume Air Flow "A" Circuit Range/Performance - Air Flow Too High.
The AMF sensor was then replaced, which lasted about an hour before the error returning. Although there is the chance that this new one is faulty as well, it seems more likely that something else is causing it.
I always prefer to work on my own vehicle so bought a scan tool to try and see what is going on. From the live data the air mass seems to follow the trend of what I would expect, increases with revs, higher manifold pressure and when the erg is commanded open. Both the old and new sensors read about the same but I can't find anywhere that says what a 'normal' air mass rate is? Without knowing what's normal it's hard to work through the option of what could be wrong.
At idle I'm getting around 7.5g/s with the erg commanded at about 50% and 17.5g/s with the erg commanded off (once the malfunction warning has appeared).
Sorry if this info is already listed somewhere but I really couldn't find it. Any help would be much appreciated. Cheers
