wizkid2003 wrote:HI all. I have a 2015 Tourneo minibus. There is a rattle from the drivers side sliding door,definitely within the trim. The trim is the one with the blinds. Ford recently replaced the trim (under warranty) but the rattle (and squeak) is still there. Does anyone or has anyone removed this trim and how complicated is it? I don't wanna go back to Ford just yet and would rather investigate myself. Any help is appreciated.
Camper steve wrote:wizkid2003 wrote:HI all. I have a 2015 Tourneo minibus. There is a rattle from the drivers side sliding door,definitely within the trim. The trim is the one with the blinds. Ford recently replaced the trim (under warranty) but the rattle (and squeak) is still there. Does anyone or has anyone removed this trim and how complicated is it? I don't wanna go back to Ford just yet and would rather investigate myself. Any help is appreciated.
there was a thread here on door rattles, if you search for it. i seem to remember lots of photos, both of the door mechanism (which rattles) and the trim rattling against the door frame.
kazoo_u wrote:I removed mine when converting to a camper to add insulation in the doors. Along the bottom there are 4 (off top of my head) plastic expanding inserts which you unscrew then pull out. On the rear edge of the panel there are some torx screws and I removed the door handle trim but don't know if you need too. Then pull away from door to release push clips. One or two of these pulled the glued bracket off the back of the trim and just had to reglue them. Be aware of the door switch pin in the rear of the door openning too as I snapped one when refitting the trim.
