2014 Transit Custom - Broken Piston
Re: 2014 Transit Custom - Broken Piston
Postby karl » Thu Nov 30, 2017 10:10 pm
V184 wrote:
karl wrote:a holed piston is over power for the engine / or the oil pump has failed
how would the oil pump failing hole a piston :? surely it would seize the engine
am only going of what he has said
nothing more or less :roll:
karl
Tranny Lover!!!
Postby Nederbelg » Thu Nov 30, 2017 11:54 pm
Probably a faulty Oil Pump would cause the Oil Jets under the Pistons to spray not enough oil for Piston cooling and thus cause piston failure.
Gr Nederbelg
Nederbelg
Postby V184 » Fri Dec 01, 2017 9:39 am
Nederbelg wrote:Probably a faulty Oil Pump would cause the Oil Jets under the Pistons to spray not enough oil for Piston cooling and thus cause piston failure.
Gr Nederbelg
What and put a hole in it :?
V184
Postby Mike » Fri Dec 01, 2017 9:45 am
It’s very rare that I agree with V184, but in this instance I have to. If the pistons aren’t getting any oil sprayed into them, the cam, crank etc certainly ain’t.
Mike
Wind up merchant!
Postby TallPaul » Fri Dec 01, 2017 12:46 pm
My guess would be if the pistons aren't getting oil sprayed under them (along with any other issues), they may be overheating, this could cause them to hole, same as detonation on a petrol engine?
TallPaul
Postby karl » Fri Dec 01, 2017 9:51 pm
Mike wrote:It’s very rare that I agree with V184, but in this instance I have to. If the pistons aren’t getting any oil sprayed into them, the cam, crank etc certainly ain’t.
:lol: ffs u feeling well :shock:
karl
Tranny Lover!!!
Postby karl » Fri Dec 01, 2017 9:54 pm
Gr Nederbelg
when we say hole its a bit like thermal cracks in the alloy piston
so in theory I like to say holed piston. And melted pistons well you tell me what you think
karl
Tranny Lover!!!
Postby moley551 » Fri Dec 01, 2017 11:35 pm
EGR valves are also used to limit combustion temperature to reduce NOx emmisons, so a faulty valve, delete or poor map won't help.
"Don't find fault, find a remedy"
H. Ford
moley551
Postby Mike » Sat Dec 02, 2017 10:30 am
Don’t worry, I’m better now :mrgreen:
Mike
Wind up merchant!
Postby V184 » Sat Dec 02, 2017 1:43 pm
TallPaul wrote:My guess would be if the pistons aren't getting oil sprayed under them (along with any other issues), they may be overheating, this could cause them to hole, same as detonation on a petrol engine?
if the oil pump failed the crank would seize long before :roll: this would happen, over-fuelling cracks/ holes pistons, di s used to do it even with the "holy" Bosch pump although more common with the cav pump !
V184
Postby TallPaul » Sat Dec 02, 2017 6:30 pm
I’m not a mechanic so I’m almost certainly wrong but I thought underfueling is what causes cracked/holed pistons due to running lean and too hot?
TallPaul
Postby V184 » Sat Dec 02, 2017 6:54 pm
think thats the case on a 2 stroke mate i had it on a rd400 many years ago :cry:
V184
Postby Mike » Sat Dec 02, 2017 8:13 pm
TallPaul wrote:I’m not a mechanic so I’m almost certainly wrong but I thought underfueling is what causes cracked/holed pistons due to running lean and too hot?
On a petrol engine, yes. Diesel rpm is relative to the amount of fuel being pumped in (not throttle position), so under fuelling will just slow the engine.
Mike
Wind up merchant!
Postby bigjohnthomas » Sat Dec 02, 2017 10:48 pm
i fooked my old hilux up by running it low on oil
crank and cam were good just put new set of standard bearings in but a couple of pistons melted to the bore
that had those spray things under the pistons
the dude i got to machine the block said i was a knob for running it low on oil and that was what made them melt
i went to rainford and back bottomc f the dipshit :o
bigjohnthomas
Postby moley551 » Sat Dec 02, 2017 11:47 pm
To limit NOx emmisons and reduce pumping losses from compressing air thats not needed for combustion diesel engines now have an intake flap to act like a throttle and control air when needed, the egr valve can be used to warm the engine quickly and also to reduce the oxygen available for combustion reducing the combustion temperature that produce higher levels of NOx.
H. Ford
moley551
Return to Transit Custom
