Rear camera not working 2014 custom sport
Postby sladeyboy1 » Mon Nov 06, 2017 8:31 pm
Anybody had there rear camera fail? A while ago the picture on my rear camera went sort of blurry off and on. Then it was ok for a while. I get in the van today and the screen was just blue. Then after a while again it goes back to normal. I just went to reverse yup my drive and the camera does not come on at all.
Has anybody else had problems with their cameras and what did they do to fix it??
sladeyboy1
Re: Rear camera not working 2014 custom sport
Postby loot » Sun Nov 12, 2017 11:43 pm
There's a thread around here somewhere, might need to search for it, i think the answer was a software update by Ford but i can't remember, although i think Ford will be aware of it.
Ids map here
loot
Postby Eurotransit » Wed Nov 29, 2017 1:37 pm
I just experienced this last week. The post that I found, suggested a wiring issue form the doors opening and closing damaging wires. I felt this was probably not the cause as my fault appeared without ever touching the doors. Still: I opened the doors, wiggled the wiring between body and door a bit and low and behold, camera comes on as normal.
I still need to actually check the wiring and the connector on the camera, but it seems to be wiring related after all.
Eurotransit
Postby Mike » Wed Nov 29, 2017 6:29 pm
They don't like frosty weather.
Mike
Wind up merchant!
Return to Transit Custom
