moley551 wrote:I've just had one repaired, £22 all in on flee bay mine had a dead battery, they break the key open and solder in the new one, now good as new....how much was a new key?
TallPaul wrote:Could it be a problem with the van not charging the key rather than a fault with the key itself?
transit custom wrote:TallPaul wrote:Could it be a problem with the van not charging the key rather than a fault with the key itself?
That’s what I said to ford could it be the transponder in the roof lining but they think not . They said it mite be my aftermarket immobiliser interfering with it . But it’s been ok for 10 months
BHM wrote:transit custom wrote:TallPaul wrote:Could it be a problem with the van not charging the key rather than a fault with the key itself?
More likely a plasma conduit leaking
BHM
loot wrote:How do you know it is sending a signal?
philmedomsley wrote:Does your van have two batteries? I had the same problem when the second battery was on the way out on our van. Replaced battery problem cured.
