Transit custom key fob
Re: Transit custom key fob
Postby Altransit » Sun Dec 24, 2017 12:29 pm
transit custom wrote:
philmedomsley wrote:Does your van have two batteries? I had the same problem when the second battery was on the way out on our van. Replaced battery problem cured.
Yes it has 2 batteries
You need to get the AUX battery checked, I think it's the rear one on a Custom. You could just try swapping the two around and see what happens :idea:
Postby loot » Mon Dec 25, 2017 8:08 pm
:shock:
Altransit where did you find that info? :P
Ids map here
loot
Postby transit custom » Wed Dec 27, 2017 2:49 pm
Can you replace the bulbs in the rear compartment so it’s brighter
transit custom
Postby loot » Thu Dec 28, 2017 9:54 pm
transit custom wrote:Can you replace the bulbs in the rear compartment so it’s brighter
You can do anything you want :-)
I have 2 square lamps that have bulbs in, there are bright white led ones available and you can also add led strips if you wish :-)
You could replace the standard bulbs for led bulbs but make sure they are the correct polarity.
I would make sure there is resistance built in if you swap the bulbs for 3rd party stuff as standard led will stay dimly lit for a while, not a problem like but there it is. :-)
Ids map here
loot
Return to Transit Custom
Users browsing this forum: 4SixAuto
