tourneo custom battery
Postby Peterposh » Wed Dec 27, 2017 1:51 pm
Hi , I've got a 2017 tourneo custom bus, I was wondering if anyone knows whether it has one or two batteries under the seat to save me having to remove the drivers seat
Peterposh
Re: tourneo custom battery
Postby yasser » Wed Dec 27, 2017 4:21 pm
without telling us exactly what spec you have nobody will know. You don't have to remove anything to check, just slide the seat forward and you can see the battery box and there is a little flap on the cover that you can lift and have a look.
310 DCiV L2 Limited 155
yasser
Postby loot » Thu Dec 28, 2017 10:14 pm
I'll say all tourneo are 2 batteries aren't they? And if not, why not :?
But as Yasser says, best to have a look because Ford specs are few and far between :wink:
Ids map here
loot
Postby relu01 » Sat Dec 30, 2017 6:27 pm
According to the marketing leaflet it should have two batteries, but on my tourneo custom 2.0 (y.2017) limited I found out that there was only one battery ...
Relu01
relu01
Postby Altransit » Sat Dec 30, 2017 7:33 pm
I seem to remember from when I was looking at buying one, that twin batteries were only standard with certain options specified, otherwise it was a £175 (or thereabouts) standalone upgrade.
Postby ake » Thu Jan 04, 2018 7:05 pm
loot wrote:I'll say all tourneo are 2 batteries aren't they? And if not, why not :?
No, not standard.
Postby 5quirrel » Tue Sep 21, 2021 2:49 pm
If it is easier to remove the driver seat to get access to the batteries, can someone please confirm which 4 bolts need to be removed. Also I have a cable running to the heated seat, will that need disconnecting?
Tourneo Custom 2017 Diesel Bus 2.0 EcoBlue FWD V362 F3 1995cc 77KW 105HP YLFS
5quirrel
Return to Transit Custom
