by Matti0110 » Fri Dec 29, 2017 11:07 pm
Both vans locked with fob, if I then open with key through door the old van alarm alerts to entry a warning then seconds latter go off and will only cut out on ignition start
I presume if someone picked lock this is how it should be
The new van does not do this alarm, just carry on as normal so of someone used say a tibbee key then new van would be an easy break in
