i have acquired a broken lense on the drivers side lower fog on my sportvan , having only had a cursory look to replace it do i have to remove the washer bottle or is there a sneaky way of doing it ? thanks in advance for any abuse
I have replaced my fog lights to led a while ago and if my memory serves me right you can replace it but it will be struggle it would be very helpful if tou have flexibile ratchet extension.And you only have 2 diagonal screws.And the top one is difficult to reach.Hope this helps.
I like Veki replace mine for LED DRL's.... typically the offside is a real fiddle... much harder the the nearside. I did it without removing anything but a 14 year old with very thin fingers was needed....removal was ok replacing a little harder..
