took my van into my local garage , non ford , for its first mot. Mechanic pointed out a bad oil leak all over the lower engine and gearbox. Thank god I did the mot early as I still had 3 weeks left on the 3 year warranty !!
Just had the job done all under warranty , I believe it was the main seal behind the fly wheel , anyone else had this problem? Van has only done 25k miles.
Also got them to fix the rear squeeling brakes, turned out to be a seized calliper
