Electric window problem
Postby DrDeAtH » Sat Jan 27, 2018 1:05 pm
Drivers side window packed up yesterday, its not the switch as I've tried a new one to no avail.
Passenger window still works as it should from both switches.
Anyone have an idea or a wiring diagram. There are no clues in the BEMM.
Thanks in advance.
DrDeAtH
Re: Electric window problem
Postby Frag » Sat Jan 27, 2018 1:26 pm
Wiring breaks in door loom,if you peel back the rubber channel you may be lucky and see it,a struggle if more than one is broken as there all black....
For security reasons
Frag
Ford Technician
Postby DrDeAtH » Sat Jan 27, 2018 1:43 pm
Cheers Frag, I'll have a look this afternoon.
DrDeAtH
Postby bigjohnthomas » Sat Jan 27, 2018 1:50 pm
good luck with those black wires :lol: if its like the back 3 are slightly thicker and for the lock
give you ten quid for your spare switch :P
cash :wink:
bigjohnthomas
Postby DrDeAtH » Sat Jan 27, 2018 3:30 pm
Well, apart from about 30 black wires, there was nothing obviously broken. A pinout of the window switch and door pillar multiplugs would be handy. Although it's raining and I can't be arsed to stand out in it at the moment testing...
DrDeAtH
Postby Frag » Sat Jan 27, 2018 4:27 pm
Check fuse 35, 5A passenger fuse box.
The one in front of your left knee,just pull trim panel off.
Frag
Ford Technician
Postby DrDeAtH » Sat Jan 27, 2018 4:48 pm
That fuse is intact.
Power mirrors work.
Door locking works off the remote and door buttons
DrDeAtH
Postby BHM » Sat Jan 27, 2018 5:26 pm
DrDeAtH wrote:Well, apart from about 30 black wires, there was nothing obviously broken. A pinout of the window switch and door pillar multiplugs would be handy. Although it's raining and I can't be arsed to stand out in it at the moment testing...
You have p.m.
BHM
BHM
Postby DrDeAtH » Sat Jan 27, 2018 5:45 pm
Thanks BHM. Have replied.
DrDeAtH
Postby bambi mk 1 » Sun Jan 28, 2018 3:52 pm
Pm Mike ,he has plenty of wind up pieces :mrgreen:
bambi mk 1
Postby DrDeAtH » Sun Jan 28, 2018 4:16 pm
Update time...
Wiring between the switch and motor plug checks out.
I made up a jumper wire to prove the motor worked from the switch multiplug. It did, so it's not a bad earth or the motor itself.
All I can think of is that it's the position sensor that plugs into the top of the window motor unit.
DrDeAtH
Postby DrDeAtH » Thu Feb 08, 2018 2:51 pm
Some closure on this thread...took the door pillar plug apart today and found a mess of corrosion and a few broken pins. New door loom and a thorough clean up of the plugs has saved the day...
DrDeAtH
Postby loot » Sun Feb 11, 2018 11:26 am
Pics?
Ids map here
loot
Postby BHM » Sun Feb 11, 2018 12:49 pm
loot wrote:Pics?
Yup pics would be good as I have a side repeater and passenger electric mirror problems.... :roll:
BHM
BHM
Postby DrDeAtH » Sun Feb 11, 2018 8:27 pm
How do I do pics?
DrDeAtH
Return to Transit Custom
