Ford Transit Custom 2017 Headlight upgrade
Re: Ford Transit Custom 2017 Headlight upgrade
Postby wobblynobbly » Sat Feb 03, 2018 2:24 pm
Might be cause he's playing dead :wink:
Elvis isn't dead, he just took a Transit tdci out for a drive and hasn't got back yet :lol:
Transit 2000 (mk6) 115T330 LX SWB semi hi roof, 55plate Sold on
2018 Custom 280 l1h1 Ltd, Magnetic grey
wobblynobbly
Postby DrDeAtH » Thu Feb 08, 2018 8:19 pm
Anyone used an LED H15 bulb yet? If so, what results did you get?
DrDeAtH
Postby Veki007 » Thu Feb 08, 2018 8:22 pm
I think they tried it looks good but people say is rubbis high beam
Sent from my SM-G950F using Tapatalk
Veki007
Postby Mike » Fri Feb 09, 2018 9:05 am
As Veki says, the light output is poor.
Mike
Wind up merchant!
Postby DrDeAtH » Fri Feb 09, 2018 9:02 pm
What type was tested, projector or non projector type?
DrDeAtH
Postby Veki007 » Fri Feb 09, 2018 9:56 pm
DrDeAtH wrote:What type was tested, projector or non projector type?
H15 can be fitted only in relflector not projector.
Veki007
Postby Mike » Fri Feb 09, 2018 10:29 pm
Main beam isn’t a projector :?
I used these,http://www.ebay.co.uk/itm/110W-10400LM- ... 2085341771
Mike
Wind up merchant!
Postby Veki007 » Fri Feb 09, 2018 10:40 pm
Sorry just seen full post are they any good with high beam?
Veki007
Postby Mike » Fri Feb 09, 2018 11:08 pm
Veki007 wrote:Sorry just seen full post are they any good with high beam?
Nope, as I said, poor beam pattern and no light in the distance. Standard H15 is noticeably better.
Mike
Wind up merchant!
Postby Veki007 » Fri Feb 09, 2018 11:16 pm
Thanks for me luckily i have bi-xenon so it helps high beam a lot.This is now my headlights after a bit of upgrades.
Veki007
Postby DrDeAtH » Sat Feb 10, 2018 8:31 pm
I know that Mike, but some of the replacement lamps have a projector lens on the front...
DrDeAtH
Postby Mike » Sat Feb 10, 2018 10:38 pm
Got a link?
Mike
Wind up merchant!
Postby DrDeAtH » Sat Feb 10, 2018 10:44 pm
Just plucked off eBay, I know that these won't be of the highest quality...
https://rover.ebay.com/rover/0/0/0?mpre ... 2226352551
DrDeAtH
Postby Mike » Sun Feb 11, 2018 9:36 am
DrDeAtH wrote:Just plucked off eBay, I know that these won't be of the highest quality...
I can’t see that tiny projector lens giving out much light?
Mike
Wind up merchant!
Postby DrDeAtH » Sun Feb 11, 2018 9:33 pm
Indeed not Mike.
there aren't many options for a decent halogen though either.
The Mtec ones have a pretty poor write up, and the eBay specials will just be cheap blue light
What's needed is Philips and others to make a decent 3700K+ white output version. The standard Osram is too yellow on DRL. (Which is what I would like to change)
DrDeAtH
Return to Transit Custom
