Hykee removal
Hykee removal
Postby cycleguy » Fri Feb 09, 2018 4:15 pm
Can any of you guys tell me how to remove a hykee lock from the drivers door on a custom please
cycleguy
Re: Hykee removal
Postby yasser » Fri Feb 09, 2018 7:03 pm
i would assume it would be the reverse of fitting. If you use the search for Hykee lock or similar something will come up as there are threads on here how to fit a Hykee. The question is, why do you want to remove it?
310 DCiV L2 Limited 155
yasser
Re: Hykee removal
Postby cycleguy » Fri Feb 09, 2018 7:14 pm
yasser wrote:i would assume it would be the reverse of fitting. If you use the search for Hykee lock or similar something will come up as there are threads on here how to fit a Hykee. The question is, why do you want to remove it?
Thanks for the reply yasser the reason I need to remove it is because I'm getting a replacment van from Ford due to my current van being a pile of Sh*t I've been in a battle with Ford for 11 months with this van that's a 2017 Limited that has had a Ton of repairs prior to delivery to me. So I want to take it out to fit in the new Van I now have it out but it looks like who ever fitted it did not fit it properly as it looks like the retaining clip that fit inside the door is missing . So the next question is can anyone confirm that there is a clip that fits on the inside of the door skin ?
cycleguy
Re: Hykee removal
Postby dumper » Fri Feb 09, 2018 7:38 pm
Yes it’s the standard Ford clip to remove the lock remove the bar off the hykey lock barrel then use the key to turn the lock to the removeit out of the doo mechanism
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Hykee removal
Postby BHM » Fri Feb 09, 2018 9:26 pm
dumper wrote:Yes it’s the standard Ford clip to remove the lock remove the bar off the hykey lock barrel then use the key to turn the lock to the removeit out of the doo mechanism
Mine also has a retention post which is secured to the lock body via a small allen key. Its located on the inside where the Ford spring clip should be :roll:
BHM
Re: Hykee removal
Postby BHM » Fri Feb 09, 2018 9:36 pm
Piccy...as I have my door card off :?
Bhm (good here init)
BHM
Re: Hykee removal
Postby cycleguy » Fri Feb 09, 2018 9:59 pm
BHM wrote:Piccy...as I have my door card off :?
Thanks great picture That clip was missing when I took the lock out today so will need to get one from Ford is this a generic clip Ford use on many models or custom Specific ?
cycleguy
Re: Hykee removal
Postby dumper » Fri Feb 09, 2018 10:42 pm
Check if it’s fell off and in bottom of door the clip on mine was a bit slack so I nipped it up to get a good fir
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Re: Hykee removal
Postby Frag » Fri Feb 09, 2018 11:30 pm
They get splayed / buckled if door lock gets 'turned',only seen them on custom and mk8,mk8 doesn't have the sponge the custom has on clip....
But mk8 also has chamfered,plastic spacer, between lock barrel and doorskin on outside (as door is not flat)
Frag
Ford Technician
Re: Hykee removal
Postby cycleguy » Fri Feb 09, 2018 11:33 pm
dumper wrote:Check if it’s fell off and in bottom of door the clip on mine was a bit slack so I nipped it up to get a good fir
Just looked in the door was not unfortanatly
cycleguy
Re: Hykee removal
Postby cycleguy » Fri Feb 09, 2018 11:34 pm
Frag wrote:They get splayed / buckled if door lock gets 'turned',only seen them on custom and mk8,mk8 doesn't have the sponge the custom has on clip....
Thanks looks like I will be off to Fords in the morning
cycleguy
Re: Hykee removal
Postby cycleguy » Sat Feb 10, 2018 1:49 pm
Thanks for you help guys just incase anyone else needs this part the Part Number is 1810029
cycleguy
Return to Transit Custom
