bigjohnthomas wrote:All is good
Perfect
bigjohnthomas wrote:If there's a bulkhead. You can't get in the back from the front
And with the lock update you can't open the back from the front without the fob or somikn
bambi mk 1 wrote:bigjohnthomas wrote:If there's a bulkhead. You can't get in the back from the front
You can with the angle grinder option cant you
Altransit wrote:Are you getting in, shutting door and deadlocking with the fob, engine off
neill wrote:Altransit wrote:Are you getting in, shutting door and deadlocking with the fob, engine off
Yes , doing this , waiting for 60 seconds . The lock unlock button is deactivated as I'd expect but I'm able to open the drivers door , can't be correct
Altransit wrote:neill wrote:Altransit wrote:Are you getting in, shutting door and deadlocking with the fob, engine off
Does it, by chance, have sensors that know the fob is inside the vehicle
