bad starting
bad starting
Postby john1964 » Sat Feb 17, 2018 8:08 pm
hi im new to this i have a 2014 transit custom last sunday it broke down cant remember the fault code that come up but it mention a fault on the pressure rail switch and
high pressure pump vapour sensor after speaking to the local ford dealer i was advised to change both vehicle runs for about 10/15 min when cold then cut out it dose restart but wont idle renewed pump relay but still cut out when worn any suggestions it did have a new fuel filter about three weeks ago and was running fine until last week
john1964
Re: bad starting
Postby FJ111200 » Sun Feb 18, 2018 9:58 am
john1964 wrote:hi im new to this any suggestions
Hi. Yes, use some punctuation. :idea:
:idea: :lol: :roll:
FJ111200
Re: bad starting
Postby S60r » Sun Feb 18, 2018 10:09 am
Welcome.
My guess is the fuel filter.
Had exactly as you describe on a Ford Galaxy and there was air in the fuel system, the garage I used also used a non Ford filter.... it played up for well over a week. Took it to Ford who put an oem filter in and purged the rail and fuel system. Apparently they have a “special” tool to purge the system of air.... not sure if that’s true or not but it ran perfectly once Ford popped their filter in there.
S60r
Return to Transit Custom
Users browsing this forum: inforce
