Not starting
Not starting
Postby dan1983 » Tue Feb 20, 2018 8:51 pm
Hi i have a 2014 transit custom which broke down last friday. For a few weeks before i kept getting a message saying fuel filter blocked but had no symptoms and it would pop up maybe every 2 days then go away. On friday the van broke down and had to be towed back to my house. I thought it would be an easy fix and changed the fuel filter but still will not start. I believe it may be full of air but mechanic has told me they have self bleeders and believes it may be the pump in the fuel tank. Any suggestions before i go ahead and have the tank removed????
dan1983
Re: Not starting
Postby Rosco100 » Wed Feb 21, 2018 7:23 am
Sounds like what happened to me a few months back and ford took 3 days to find the fault and it turned out to be the fuel pump.....
Inverurie Tile Centre
AB51 3XQ
Transit 155 330 Limited
Rosco100
Re: Not starting
Postby S60r » Wed Feb 21, 2018 8:17 am
I’ve not changed a fuel pump on the custom but I’d be very surprised if you have to remove the tank!!
Most just need to be unbolted from the tank, removed and changed, new filter, re gasket and back it goes. Make sure the fuel lines are de pressurised though! A friend got a face full changing his pump out.... dangerous!
Let me know if I’m wrong as I won’t be trying that one on the custom...... it would be a crap design if the whole tank had to come off though!
S60r
Re: Not starting
Postby dan1983 » Wed Feb 21, 2018 8:38 am
If you don't mind me asking, how much did ford charge you.
dan1983
Re: Not starting
Postby moley551 » Wed Feb 21, 2018 9:33 am
You could test the pump by cycling the key with the fuel drain open on the filter, a bucket and small pipe will contain some of the mess!
"Don't find fault, find a remedy"
H. Ford
moley551
Re: Not starting
Postby dan1983 » Wed Feb 21, 2018 1:13 pm
Just tried and no fuel is coming through, can't even hear anything from the pump in the fuel tank.
dan1983
Return to Transit Custom
