S60r wrote:Yes Rich... I have often thought about this! I had a good look last time van was empty and decided a flap about 300 high off the cargo floor is the absolute max it will allow due to the rear seats.... I want to put longer timbers through. I can only get 2.4's in on the diagonal at the moment. There is a cage to prevent pushing right through to the rear passenger foot space but it will allow 3mtr lengths to lay flat..... I will multitool it out when the weather gets warmer, and make it so it can be reinstated when not in use.
I wasn't able to find any actual pre fabbed access panels for it at all, so it will have to be DIY..... unless you have found any?
I haven't found anything yet, was just thinking about it.
With my cage under the back seats, it is removable, just clips out and can be in 2 positions - I thought they were all the same, so you should be able to get longer than 3m length in
Sent from my SM-N910F using Tapatalk
