P.A.T.S Connections ?
Re: P.A.T.S Connections ?
Postby loot » Mon Mar 05, 2018 10:36 pm
The euro 5 pats is tx rx module but the euro 6 module is lin bus which means that the db3 or similar needs to be lin bus.
They say that you need to get the db3 programmed to your vehicle so unless they can do the custom or it is the same as the mk8 or it is just the fob frequency so generic Ford I can't see how it'll work.
07 350 170ps
Ids map here
loot
Postby cycleguy » Mon Mar 05, 2018 11:15 pm
I did get the DB3 flashed for a transit so lets hope it all works loot
cycleguy
Return to Transit Custom
