jinx wrote:Thanks for the replies . My petrolhead pea brain overuled and i ordered the 20 inch bolas today and apart from them looking nice i will no doubt regret it once i have hit a few potholes and kissed some kerbs. I went FOR 245 40 20 instead of 255 35 20 to slightly help. On my Merc Vito i had 18 inch staggered AMG and the front tyres would need changing every 3 months as the vito passenger side front tyre wears prematurely on the outside edge leaving 5-6mm on the rest of the tyre. I will have to start going around roundabouts like a snail but cant see that lasting oh well if you see 20 inch used bolas on ebay in the next few months they are probably mine lol
S60r wrote:jinx wrote:Thanks for the replies . My petrolhead pea brain overuled and i ordered the 20 inch bolas today and apart from them looking nice i will no doubt regret it once i have hit a few potholes and kissed some kerbs. I went FOR 245 40 20 instead of 255 35 20 to slightly help. On my Merc Vito i had 18 inch staggered AMG and the front tyres would need changing every 3 months as the vito passenger side front tyre wears prematurely on the outside edge leaving 5-6mm on the rest of the tyre. I will have to start going around roundabouts like a snail but cant see that lasting oh well if you see 20 inch used bolas on ebay in the next few months they are probably mine lol
What pressure you run?
My 18 scrub really bad unless they are well over 50 psi..... you won’t find any info on tyre pressures once you go up above 18’s so it will be a balancing act between wear and comfort
Marky M wrote:If so, give my a heads up..
I found a set of Axe wheels. Not the ex14, but the Axe transit GB.
Users browsing this forum: mic71
