cowasaki wrote:Can a camera be retro fitted to work with the ICE pack 9? Yes If so does it just come on when you select reverse? Yes Does the option need programming in when added? Yes
Mike wrote:cowasaki wrote:Can a camera be retro fitted to work with the ICE pack 9? Yes If so does it just come on when you select reverse? Yes Does the option need programming in when added? Yes
cowasaki wrote:So basically, where does it attach normally on the back?
Mike wrote:cowasaki wrote:So basically, where does it attach normally on the back?
It fits in a replacement number plate light housing.
cowasaki wrote:
So I need that too?
Is the wiring already in the van or is that the next job?
So I need that too?
Yes you’ll need that too. As for the wiring, it may well be there in a Limited or even a Trend, it could even be canbus based.
bigjohnthomas wrote:I thought,, that if you had satnav the reverse screen was in the display and if not
Like mine the screen is in the rear view mirror ?
On new models in limited and sport is in screen on dash but on base and trend is in rear view mirror that is at least what i have been told.bigjohnthomas wrote:I thought,, that if you had satnav the reverse screen was in the display and if not
Veki007 wrote:On new models in limited and sport is in screen on dash but on base and trend is in rear view mirror that is at least what i have been told.bigjohnthomas wrote:I thought,, that if you had satnav the reverse screen was in the display and if not
Sent from my SM-G950F using Tapatalk
jinx wrote:I have just had reverse camera installed on my 17 reg limited with ice pack 9 and i had to have the smart mirror as it was not compatible with the screen, not that it bothered me as the mirrror fits in like it came from the factory and the clarity is fantastic and also there was no cabling readily in place but cannot comment on the newer model that you have ordered
