bigjohnthomas wrote:The radiogram turns off when you open the door
You could open the door at the same time as you turn the key off ?
bigjohnthomas wrote:That would mean you have to switch your sat nav on and off like a poor person
Mine comes on when the vans unlocked and switches itself off 20 mins or so after the ignition is turned off
Never need to press it's button
hitech-donk wrote:I'm not sure but I don't think you'll have an ignition live at the radio anymore, I think they did away with that when they started connecting them to the canbus. There will still likely be a signal from behind the fuse box though, you'll need to check it can handle the current you will be drawing from it though.
Punto443 wrote:Why not consult the bemm?
That’s what it’s for
cowasaki wrote:Well I've been looking through the BEMM for a while and found that everything I need is in there regarding electrical connections, routing, additional battery(s) etc.
Next job is to find out how to remove the roof console and plastic cover etc at the top of the windscreen (without breaking anything)
cowasaki wrote:Thanks for that. Any ideas on the interior mirror plastics? The bits that cover the rain sensor/lane sensor etc and into which the interior mirror goes.
I want to attach a RAM mount where the rear view mirror would mount and get some wiring between the roof console and it.
