Just thought I would check my wheel nuts as I've just done the tyre pressure and popped the cover off the wheel jack space to find I have no jack or wheel brace, however I do have water in there!
Theres no sign of water anywhere else but I haven't stripped the floor up just yet, just poked my fingers under.
I've seen a few posts on water in the steps but where does it get in?
I had the same problem in my Mk7 and that was the windscreen seal which was common, do the customs suffer the same problem?
Also do the customs share the same jack set as the Mk7s?
