Location of C2-1 C2-2 & C2-3 connectors
Postby cowasaki » Mon Apr 16, 2018 1:15 pm
Having been pointed towards the BEMM I have now located the connections for most of the electrical mods I want to do. Most of the actual connections are via the above connections as per the BEMM ie C2-1 C2-2 & C2-3
This is the diagram:
But I can't actually work out where these are! I thought they might be under the passenger seat but no.... Then I looked at the picture again and it now looks like they are under the driver's seat. Before I take that apart has anyone taken the drivers seat base apart enough to locate these and can show an image or describe where I will find them.
I'm adding the additional customer connection points to the rear of the seat using the approved kit KTBK2T-14B475-A so between all these I'm sorted......
I've rebuilt a Defender, several motorcycles and quite a bit to both a Mk6 & 7 Transit. Now bought a new Custom and just doing a few small bits to it.
Cowasaki's electrical tutorials: viewtopic.php?f=2&t=166595
cowasaki
Return to Transit Custom
