Having been pointed towards the BEMM I have now located the connections for most of the electrical mods I want to do. Most of the actual connections are via the above connections as per the BEMM ie C2-1 C2-2 & C2-3
This is the diagram:
But I can't actually work out where these are! I thought they might be under the passenger seat but no.... Then I looked at the picture again and it now looks like they are under the driver's seat. Before I take that apart has anyone taken the drivers seat base apart enough to locate these and can show an image or describe where I will find them.
I'm adding the additional customer connection points to the rear of the seat using the approved kit KTBK2T-14B475-A so between all these I'm sorted......
