2013 Transit Custom oil leak
Postby spookydan » Sun Apr 22, 2018 7:57 am
Hi,
I have an oil leak from the engine of a 2013 Transit Custom on the drivers side. The photo's show what's above the leak stain, which was black in colour so I assume engine oil. Engine has done 40k miles.
Does anyone know what is likely to be causing the leak?
spookydan
Re: 2013 Transit Custom oil leak
Postby DrDeAtH » Sun Apr 22, 2018 9:29 am
I'd be inclined to clean that off with some spray in gunk degreaser. At least you'd then be able to see properly if it is an oil leak, or just spillage from topping up the engine/power steering.
DrDeAtH
Return to Transit Custom
