loot wrote:What info do you need specifically? I'm guessing that the euro 6 bcm is the same as the euro 5 but possibly a different pcm.
Might both be different but I don't see why.
Paul or Dave will know part numbers though.
cycleguy wrote:loot wrote:What info do you need specifically? I'm guessing that the euro 6 bcm is the same as the euro 5 but possibly a different pcm.
I need to know where the - lock and unlock wires are
loot wrote:Won't the 18.5 be the new shape custom?
loot wrote:Won't the 18.5 be the new shape custom? But yes anyway bemm will help you.
In the mean time is this any good?
loot wrote:Yes I've noticed that a few times, although I've yet to do any work on the mk8/custom bcm and so I don't know how the connector/pin numbering works mk7 was as you know c1 etc pin 1 etc.
How they are numbered on the bcm I don't know.
Although going from the fact that all of the diagrams are like layers, I wouldn't be surprised if you actually interact with them online with etis.?
Who knows?
cycleguy wrote:Hi there guys on page 163 of the Ford BEMM there is mention of the connection I need to get on Pins 4 and 5 and they refer to a Connector C2-1 (Figure E169183 - Item A but I cant seem to find figure E169183 there is a picture above on page 162 that shows some connections under the drivers seat this picture has a E201841 which I would not expect the have the door lock wires under the seat ?
