loot wrote:If i was doing it I'd use a 60A feed from the drivers seat base to feed the main live with a suitable contact switch, chassis ground and I would look at using a remote cable for switching.
That's how my power inverter is setup.
Assuming you mean audio amplifier then you'd want a radio on feed or simpler an ignition live feed.
There are a few variations to the above, you can feed the cable in the side of the van fairly simple.
loot wrote:You can work on the live fused feeds at the seat base without removing the battery but just be careful that you don't ground them or you'll blow their respective fuses.
I'm not 100% sure about cab floor cable routing but if it is similar to the mk7 then it goes from drivers seat to bcm/glove box area via the floor.
It may show you what you need if you go to http://www.etis.ford and put your vehicle vin in and download bemm transit custom 2012.75 or whatever you need.
