2017 Custon Service now message
Postby Dywlc » Thu May 31, 2018 1:22 pm
The service messaage has appeared on my Custom after only 2500 miles. I've tried the two pedals to the floor method after switching the ignition on and before switching the ignition on but no avail. My local non dealer workshop hooked it up and reset it they say but after 21 miles it's back. I leave for France, Italy, Austria Switzerland, Germany, Luxembourg and Belgium in two days time. Any ideas how to reset this myself anyone? It's the 2.0l 170ps 2017 pre recent facelift model
Dywlc
Re: 2017 Custon Service now message
Postby FJ111200 » Thu May 31, 2018 3:32 pm
How long are you waiting with your feet on the brake and accelerator pedals? It can take up to 90 seconds.
:idea: :lol: :roll:
FJ111200
Postby bigjohnthomas » Thu May 31, 2018 3:57 pm
Isn't that the engine malfunction message?
bigjohnthomas
Postby bigjohnthomas » Thu May 31, 2018 4:49 pm
Now then ,now then guys n galls howz about that them ?
Is it this one ?
viewtopic.php?f=65&t=182617&hilit=Service+now
bigjohnthomas
Postby p2thed » Thu May 31, 2018 7:47 pm
Is it "service now" or "engine service now"
If its the first then its more than likely needing an oil change and pcm update under warranty.
If its the second then thats an eml, at low miles most likely causes are
1. Map sensor loose(they are meant to be disconnected when stored)then clicked back in at pdi.
2.faulty injectors/pcm update
3.egr valve position sensor
2.0 ltr engine service lights are reset through the dash cluster using the wheel controls. If you reset the light and it stays out then you will know the answer the my forst question.
p2thed
Return to Transit Custom
