Hi
I have changed the rear discs and pads along with off side hub as the bearing fell apart while removing it.
I now have hill start unavailable, traction control light and ABS light on. I did leave the MAF sensor off by accident while moving the van out of the workshop but reset the DTC's.
There is a loud buzzing after i switch the van off and it has no active or pending DTC's and drives fine.
Front discs and pads were changed about 3k ago with no issues.
Any help where to start fault finding?
