My van has dab on but I can't get a reception
haven't tried looking at the antenna or anything.
My radio is the standard nav and dab version.
The centre screen is bigger and is a colour lcd 1 which also does the reverse camera.
You'd need probably a few things to upgrade and possibly configuring at Ford but I'm not sure.
You can buy a fascia.
Bloody steep though !
A point I'd make is that I wouldn't touch it unless my van was all low spec instruments etc as it is all can bus.
Mine is high spec speedo with large colour display and centre lcd display with sat nav and front and reverse sensors.
Can't imagine what removing my stereo would do to the van
Standard small blue display low spec would probably be more like the mk7 so probably a straight swap
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
Ids v86 licence + v86.04 update + xprog
hereIds map
here
