Engine Run wire 2013 VN
Postby factotum » Sat Jun 09, 2018 5:16 am
I've been slowly redoing the hideous work done by the people who fitted my trailer adaptor some years ago and adding an e-brake controller and other stuff.
Clearly it was too hard for them to put the trailer controller in properly so they stole power from my inverter nearby, tapped in to the RHS brake lights and were too lazy to put it in the "bulkhead" so they stuffed it in behind the rear light cluster!
But I digress... What I'd really like is to locate an "engine run" wire nearby. I've trawled the BEMM and can't seem to work this one out. For bonus points a feed from the Engine battery would also be good so I can take all the trailer stuff off the permanently powered auxiliary battery feed to my inverter.
Any pointers appreciated...
Ford Transit Custom 2013 VN
factotum
Re: Engine Run wire 2013 VN
Postby factotum » Fri Nov 25, 2022 3:48 am
It’s been a while and I’m back to this project.
Anywhere close to the rear doors I can find ignition power?
I thought I found it with the lighter socket in the rear but that’s permanent power :(
I have run a spare wire to the under seat fuse box so figure I can pick up something there instead…
factotum
Return to Transit Custom
