Passenger seat airbag
Postby kazoo_u » Tue Jun 12, 2018 8:18 pm
If I want to change the double passenger seat that has an airbag label on the back edge of the seat, do I need to fit a single with an airbag or can I bypass it or get it programmed out? I have read about putting a resistor in the circuit to trick the computer into thinking it’s still connected. It’s a 2016 Tourneo Custom which I’m converting to a camper.
Mk7 T260 swb 85ps camper self build. Roofrack with inset solar panel, Vantuner enabled cruise control.
kazoo_u
Re: Passenger seat airbag
Postby kazoo_u » Sun Sep 23, 2018 10:19 pm
Fitted single seat tonight without an airbag and used a 2.2 ohm resistor to remove airbag warning light.
kazoo_u
Return to Transit Custom
Users browsing this forum: Fannyd69
