Thequeenscheese wrote:Hasn't anyone updated them for led etc??
Thequeenscheese wrote:I usually have the osram nightbreakers in my motors but is it time to go led ? What are you guys using?
bambi mk 1 wrote:Most guys on here use the search function,its quite easy after the first time top right of the page It saves people answering the same questions over and over again If you need help I can search for you
Mike wrote:bambi mk 1 wrote:Most guys on here use the search function,its quite easy after the first time top right of the page It saves people answering the same questions over and over again If you need help I can search for you
It’s been posting daft questions ever since it’s been here. It’s common these days. Snowflakes are taking over the forum.
bambi mk 1 wrote:Thequeenscheese wrote:I usually have the osram nightbreakers in my motors but is it time to go led ? What are you guys using?
AusTansit wrote:https://www.stedi.com.au/copper-head-h15-led-head-light-conversion-kit.html
I put these in my transit custom 2017. For high beams.
Good improvement in light output.
Only downside is you don’t get a good uniformality of light coverage.
So am now installing a light bar as well
Thequeenscheese wrote:The H15 are for the projector bit I think yours are just halogen by the looks?
Mike wrote:Thequeenscheese wrote:The H15 are for the projector bit I think yours are just halogen by the looks?
Incorrect.
Thequeenscheese wrote:bambi mk 1 wrote:Thequeenscheese wrote:I usually have the osram nightbreakers in my motors but is it time to go led ? What are you guys using?
And nobs always moan when someone uses a forum as a forum not as a google search engine.
