New boy
New boy
Postby Ian9525 » Wed Jul 11, 2018 1:20 pm
Hi all... I have just bought a 2015 Custom van.. I will be fitting it for basic living.. It has the cutout for a cigarette lighter in the rear offside door post which apparently has a wiring plug on the loom somewhere nearby (according to You Tube)to connect into.. I cannot find this plug anywhere so am wondering, do Ford still install these on the loom. I did find two heavy duty looking wires without a plug of any sort, I tested these to see if power was present in all stages of ignition key, and nothing !!!
I have removed the MDF panel on the rear nearside to search in the loom behind it, I have found a small plug on the loom with two wires, one is Black/blue and the other is solid yellow, does anyone know what this plug is for ?
You cant educate Pork :roll:
Ian9525
Return to Transit Custom
