by AusTansit » Sat Jul 21, 2018 9:45 am
I don’t know for sure.
But I removed my front bumper the other day and the grill came off with it attached to the bumper.
Was pretty easy to remove the bumper.
1. Remove the two TX screws on either side of the wheel arches. Two hex screws per side.
2. Remove the two bolts behind the number plate.
3. Remove the plastic stone guard underneath bumper. About 5 TX screws. And one plastic fastener attached to a hose.
4. Disconnect the main electrical connector to the bumper. Located underneath on the drivers side next to the wind screen washer tank. There is a couple of cable clips you have to remove too.
4. Start peeling away the bumper. Starting from the wheel arches. Working your way to the centre of the bumper.
5. Bumper should come off with a bit of pulling and tugging.
