Cooling Fan comes on seconds after start up from cold
Postby wild camper » Thu Aug 09, 2018 2:46 am
2017 2.0 EcoBlue 130ps
I have this intermittent fault when the cooling fan comes on seconds after a cold start. I want the engine to reach operating temperature and the fan is cooling it down. I mentioned it to the Ford Service Rep. and he booked it in, he wouldn’t give me an early appointment so I could wait but arranged to collect the van and said it may take all day and may have to be kept overnight.
I’ve done a search and it may be simply the A/C distribution position or threads going back years about an incomplete “regen”. Has anyone had this same intermittent fault?
What does the Service Rep. know but is not telling me?
When I reverse the van into the garage I’ve noticed very acrid exhaust fumes, much stronger than previous vehicles, I thought it had something to do with the AdBlue system but this might be related to my cooling fan fault.
wild camper
Re: Cooling Fan comes on seconds after start up from cold
Postby hughesyn » Thu Aug 09, 2018 7:41 am
Why would the cooling fan coming on stop the engine warming up?
There is a thermostat in the coolant flow that bypasses the radiator when cold.
In the days of belt driven fans, the fan ran all the time.
I wouldn't worry about whether the fan runs or not.
2023 Mk8 DCIV 170 auto L3H2
hughesyn
Postby Brains_transit » Thu Aug 09, 2018 11:04 pm
When ac is on in my car the fan will start up even when the engine is cold
Brains_transit
Postby bigjohnthomas » Thu Aug 09, 2018 11:17 pm
My custom does that too when the aircons on
All is good perfect
Have a fag watch some lezbo porn and try to relax 8)
bigjohnthomas
Postby Altransit » Thu Aug 09, 2018 11:19 pm
Brains_transit wrote:When ac is on in my car the fan will start up even when the engine is cold
What he said ^^^^^^^^^^
If the AC is on the fan runs pretty much all of the time.
If you have the air flow set to "screen" the AC is on regardless of the on/off AC switch :)
Postby wild camper » Fri Aug 10, 2018 6:40 pm
I’d read the comment about the A/C position “dial” being set to windscreen on an earlier thread, so I turned it fully anti-clockwise to “in your face” and it still does it.
It’s an intermittent fault, it went days without doing it, but did it again this afternoon, I hope the Ford Diagnostic Kit can recognise it.
Surely the Ford Service Rep. would know if it was as simple as turning off the A/C to cure it and not incur a lot of cost in having the van collected and returned?
I agree with the earlier post that belt driven fans rotated all the time but there was usually a temperature sensitive coupling that reduced the cooling effect of it was cold.
Electric fans are operated off a thermostat, the idea is that they don’t operate if the engine is cold.
I got off lightly with the comment from bigjohnthomas, he usually uses more acidic witticisms.
wild camper
Postby wild camper » Fri Aug 10, 2018 6:49 pm
Perhaps I should clarify— it does it when the A/C is off. Fan speed dial is fully anti-clockwise to off. air distribution dial is fully anti-clockwise to “in your face”
I don’t think it has anything to do with the A/C.
wild camper
Postby bigjohnthomas » Fri Aug 10, 2018 7:14 pm
If it's intermittent then if it doesn't do it at the dealers they won't find it :D
bigjohnthomas
Postby wild camper » Fri Aug 10, 2018 7:48 pm
I was relying on the Ford Diagnostic Equipment to be able to pick up fault codes even if it doesn’t do it while the vehicle is with them.
I’m hoping that it does it when it’s cold when it’s collected by the Ford driver.
I might video it (at least I’ll get the sound of it) next time it happens, I could try to attach the video to an email and send it to the Ford Garage in case it doesn’t happen while they have it.
wild camper
Postby bigjohnthomas » Fri Aug 10, 2018 8:13 pm
some stuff dosent store fault codes
my inlet sensor kept putting it in limp mode with no code found unless its actually doing it
bigjohnthomas
Postby hughesyn » Fri Aug 10, 2018 9:40 pm
Doesn't sound like a fault to me.
Why does it matter if the fan comes on?
I think Ford will tell you to hop it.
hughesyn
Postby wild camper » Sat Feb 16, 2019 5:46 pm
I’ve put up with this fault for months
I got no joy from the Ford mechanics
In the cold weather it wouldn’t reach a decent temperature after an 11 mile journey
I decided to change the the thermostat myself but found that I can’t just change the thermostat but have to buy a “housing “ c/w thermostat and sensor
It costs £80+, so I’m determined to have it fixed under warranty
I took a photo of the odometer and temperature gauge at the start of a journey and photo after 11 miles and sent it to the service desk
I’ve got it booked in again next week, they want to keep it overnight so arranged a hire van for the period
They say they’re not allowed to order in a new housing before I take it in
I’ve had to fabricate a radiator “muff” to cover the grille to improve the warm up time
The fuel consumption is very poor too
I’ll post here to advise if anything is replaced and any improvement
wild camper
Postby longhair » Sat Feb 16, 2019 10:09 pm
You can get just the thermostat at most motor factors or eBay for around 12 quid. Might not be genuine ford part but as long as it opens at 88 degrees, I would try that.
longhair
Postby Kardaani » Sun Feb 17, 2019 9:42 am
Whats the weather where you are living? Wondered about same thing with the fan and Ford service told me: "When AC is on the fan runs allways, until the tempertature drops below +5c (41 Fahrenheit)."
Kardaani
Postby longhair » Sun Feb 17, 2019 10:23 am
Just ignore my last reply. I just realised you have a euro 6 one, so you are correct you need the whole housing. Good luck getting it sorted anyway.
longhair
Return to Transit Custom
cron
